[#1] Try to found ppls with classic amigas and gfx boards for pure tests.
Hi all.
If you have classic amiga with any warp3d support video board
If you have some time
If you want to help me with pure tests of some scene related stuff
Write me plz at kas1e@yandex.ru.
[#2] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #1
I have sent answers that already two day ago, have come mails?
[#3] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@] SKOLMAN_MWS ˇ agrEssOr [, post #2
No :( Strange .. btw, did you have icq number ? maybe best choice talk in icq ?
[#4] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #3
I use only Gadu-Gadu and IRC http://irc.ppa.pl
I have sent again mail, now it can come :)
You have other address it accept spam? ;)
[#5] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #1
Na moim sprzęcie wyłażą wszystkie błędy. Możesz podesłać ten stuff :)
[#6] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #3
Run icon/cli AOS39. First screen black play music piano,
next screen menu.png and music play, exit ECS done...
http://skolman-mws.w.interia.pl/test/invtro.png
http://skolman-mws.w.interia.pl/test/setscrmode.png
http://skolman-mws.w.interia.pl/test/menu.png
10.Ram Disk:> RAM:
10.RAM:> dir
invtro (dir)
10.RAM:> invtro
10.RAM:invtro> dir
data (dir)
invtro invtro.info
readme.diz
10.RAM:invtro> stack
Aktualny rozmiar stosu 200 000 bajtów
RAM:invtro> invtro
Warp3D init......ok!
JPEG init......ok!
CGX init......ok!
Decompress data......ok!
Load PT Modules.....ok!
warp3d context success!
Get naked mouse pointer ....ok!
Load all textures to ram.....ok!
Closing down...
Count Process Name Action Target Name Options Res.
1 WBL ChangeDir Ram Disk:invtro
2 WBL Load invtro OK
3 WBL ChangeDir SYS:
4 invtro ChangeDir Ram Disk:invtro
5 invtro Open con:10/10/320/80/invtro/aut Write OK
6 invtro Open * Read OK
7 ramlib Load LIBS:Warp3D.library OK
8 ramlib Load LIBS:Permedia Fail
9 ramlib Open LIBS:Permedia Read Fail
10 ramlib Load Permedia Fail
11 ramlib Open Permedia Read Fail
12 ramlib Load LIBS:libs/Permedia Fail
13 ramlib Open LIBS:libs/Permedia Read Fail
14 ramlib Load libs/Permedia Fail
15 ramlib Open libs/Permedia Read Fail
16 ramlib Load LIBS:Warp3D/GFXdrivers/W3D_ OK
17 ramlib Load LIBS:rtg.library OK
18 ramlib Load LIBS:libs/rtg.library Fail
19 ramlib Open LIBS:libs/rtg.library Read Fail
20 ramlib Load libs/rtg.library Fail
21 ramlib Open libs/rtg.library Read Fail
22 ramlib Load LIBS:Warp3D/HWdrivers/W3D_P OK
23 invtro Open PROGDIR:data/gfxs/new_line_ Read OK
24 invtro Open PROGDIR:data/gfxs/lenta_128 Read OK
25 ramlib Load PROGDIR:data/libs/ptreplay. OK
26 invtro Open PROGDIR:data/snds/8minutes. Read OK
27 invtro Open PROGDIR:data/snds/intertain Read OK
LIBS:Permedia ?
my rtg version - http://main.aminet.net/gfx/board/rtgmaster_user.lha
my driver monitor 68k - http://skolman-mws.w.interia.pl/files/BVPPC_43.lha
Test MorphOS 145 Classic no run my BVisionPPC.
Rave3D drivers MorphOS not support gfx Permedia2 :(
[#7] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@] SKOLMAN_MWS ˇ agrEssOr [, post #6
Hi Skolman ! Thanks for answer ! (my mail is suck as i can see.. well, i send to you new mail addr now).
btw, i setup amigg,it is not so hard for me talk in polish, becouse i am russian, but hard anyway. I can setup it, and added you for me, but you offline around 20-30 hours for me :) (or maybe i sleep in this time when you coming).
Anyway. I try to test this stuff for other bvision too, and have the same rezult. All is work, but colours is ugly and the same screenshot !
I am not use permedia libs .. only Warp3d.library. But, maybe i do in code somethink, thank can do only voodoo ? i mean warp3d.library watch that i can do W3D_SetState(somethink) for example, and try to open permedia libs .. Or maybe for bvision it is try to open some unused directory for tests .. Like 'if not permedia for this driver, so it is bvisoin'
Anyway, i do not do anythink 'great' in code, as i said - it is pure tests. But thank very much for it.. And if you have some more time, we can talk in Amigg by online, and can found where is problem (becouse i want to support voodoo/bvision as minimum, but mos/aos4 good be too).
So, i write you new mail.
[#8] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@Prince, post #5
speak in english plz, it hard to understand for me.you mean ' On your amiga all errors will found. send it to me' ? or what ?:)
[#9] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #8
On my equipment go out all error. You can send it stuff :)
It is necessary to learn polish language, good language polish. Poland not Haway :D
Yes ;)
> send it to me'? or what ?:)
You mail stuff for Prince.
[#10] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@] SKOLMAN_MWS ˇ agrEssOr [, post #9
skolman!:) still can't found you in amigg and not recieve any mail answer :) thanks for translate:)
[#11] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #7
No problem :) New mail maybe OK, test now.
Graphics can not open restore for definitely permedia and it gets silly :S
Know you from russia Michael Malyshev?
[#12] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@] SKOLMAN_MWS ˇ agrEssOr [, post #11
mail works ok now :)
michail malichev - cbug ? not as friend, but know, yes
btw, did you know someone else with bvision ? i need more deeply work over it :)
[#13] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #12
BVision has Michael_Malyshev(monkey)mail.ru :)
Fairest and I saw most fast (engine) program for showing that ever png, vPNG made by Viktar Pakhomau
http://aminet.net/package.php?package=gfx/show/vPNG.lha
http://aminet.net/package.php?package=util/dtype/vPNGdt.lha
[#14] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@] SKOLMAN_MWS ˇ agrEssOr [, post #13
btw,i hope i finish bvision version of my sucking stuff already :) so, last changes and i will send to you new archive :) plz, check a mail :)
[#15] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #14
thanks all for help. skolman, to you of course first :) if anyone in interest, here is ready version of this faty/lame crap :)
http://aminet.net/demo/mag/lamintvro.lha
[#16] Re: Try to found ppls with classic amigas and gfx boards for pure tests.
@kas1e, post #15
